跳转到主内容
加入维修社区 - 创建账户
Dell 1710n 是一款于 2011 年发布的办公激光打印机。
How to remove white 'scuff'marks on print jobs?
Had no problem until this week - my 1710 printer is not printing clearly, there are scuff marks that repeat in 'white cloud' shapes down the page in regular intervals. I have pulled out the printer catridge etc and have wiped out excess toner internally via the front panel. Is this problem caused by a piece of paper stuck on the rollers ?? The dell toner cartridge is hardly used, as new.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This is generally due to a scratch in the drum unit. Sometimes light damage, but it's very often that the drum got scratched at some point. Take the drum out and inspect it for damage.,
In almost every case, light damage is permanent. I have had to condemn two drums for light damage ghosting on Lexmark machines because I got them used from sellers who left the drum out too long. Sometimes, they recover if you refrain from use for a bit, but very often, the damage is done. Other times, it might be recoverable, but the drum is already well run, so the odds of recovering aren't great. If the drum is cheap or you have one ready, replace it and move on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Johanna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 1,446
