跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Areas of screen unresponsive to touch after screen replacement
I am just about done with the iPad 6 Wi-Fi Front Panel Assembly Replacement procedure. The LCD is screwed back in with the new touchscreen connected. I turned on the iPad to test the touchscreen (before final step of removing adhesive strips and securing touchscreen down).
Home button works fine - iPad lights up and when I go to enter my code, the 4, 5, 6, 7, 8, 9, and 0 all seem to work but the 1, 2, and 3 buttons do not respond to touch. “Delete” and “Cancel” text buttons both work.
I am able to power down (by sliding across the top of the screen) fine. Tried a hard reboot but same issue persists.
Is this a problem with the iFixit replacement screen or could there be another issue?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Oh yeah I get this a lot with my iPad 6 screens just disconnect the screen cables and reseat them. For every one I do I plug them in two times to make sure.
I'm not sure why but with first click in it sometimes has dead spots on touch but when I reseat it is all working fine. Make sure to push down a bit harder than usual on each ends to make sure they are fully clicked into connector.
这个答案有帮助吗?
得分 3
3条评论:
Thanks! I will try this and report back!
完成的
Belated update: this fixed it - thanks!
完成的
I'm replacing a new screen. 4 5 6 and above doesn't work, below that works. What itmeans "in two times"? Pluging the connectors restart and then unpluging and puld the connectors again? Thx in advance.
完成的
添加一条评论
添加你的答案
Matthew Wilson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 2,249
