跳转到主内容
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
211 个问题 查看全部
Airpods pro range got worse
Hello,
Until yesterday, I had a Macbook Pro 13” 2018. Paired to it, the Airpods Pro. I was very surprised that the headphones worked not only in the openspace-office, but also in the workshop which was at ±25m (air)distance and separated by a concrete wall. Today I switched to the new Macbook Pro 16”. The positive surprise from yesterday turned into a very negative one: As soon as I’m at a distance more than 10m from the notebook, the music cuts. Same application, same software configuration (Migration assistant), only new MBP. Does the new MBP have a much weaker bluetooth antenna, or “what the range” happens?
Thx in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Just looking at the teardown between the 2019 16” and the 15” models you can see there is really no difference in the antennas
2019 MacBook Pro 16”
2019 MacBook Pro 15”
Looking at the logic boards we can see a slight difference! Light Blue marked chip Wi-Fi/Bluetooth module
2019 MacBook Pro 16” - 339S00610
2019 MacBook Pro 15” - 339S00458
While the chips them selves have different markings, as these are custom chip we just don’t know what’s different inside.
Both list WiFi 802.11ac & Bluetooth 5.0 support so I can’t see a reason to alter the WiFi/Bluetooth transceiver chip.
So… I would double check another system to see if you got a bad one. The antenna cables could be damaged or could have been connected incorrectly.
这个答案有帮助吗?
得分 1
2条评论:
Hello, Dan
Thanks for your response. Today I was with both notebooks to the Apple Service. Showed them the phenomenon. Answer was “it’s normal that the range is 7-10m, as bluetooth is working at this distance”. I showed them that the old one is working at a much higher range and showed them your suggestion. They opened the new MBP16, checked antenna connection, said it’s correct, and again reassured me that the range should not be more than 7-10m. Therefore…it seems it’s the old MBP’s “fault” to wok at that big distance. And no, I havent been with it to Chernobyl :)
完成的
With the 10.15.2 update (build 19C57), the problem seems to be patched and the range is the same as with the old MBP.
完成的
添加一条评论
Running MacOS 10.15.6 and still have bluetooth range issues….
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
danms84 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 17
总计 1,053
