跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
SSD and ram replacement of 2009 iMac stuck on loading bar
Late 2009 27 inch iMac with i7 had its hard drive die on me. Decided to try to replace it and upgrade to an ssd. I bought a 1tb wd ssd from Best Buy and 16 gb of Corsair Mac memory ddr3 1066 MHz. I first tried to install El Capitan and it worked in safe mode. However when booted normally it would end up in white screen only. I tried to install high Sierra afterwards and it still works in safe mode. In normal boot it just gets stuck on loading screen. Looking for suggestions on what to try. Have done a reinstall of OS X and cleared ram and other key combos. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I think you’re hitting a known issue! Your system’s SATA port is only SATA II (3.0 Gb/s) While the drive you are trying to use is a fixed SATA III (6.0 Gb/s) drive which is too fast an I/O for your system.
This gets into the way the SATA standard was written. At the time the expectation was people would transfer their older drives to their new systems as HDD’s back then where quite expensive! Who knew the price of HDD’s would drop and the desire for deeper storage would also push us to larger drives.
In the meantime the SATA standard jumped from SATA II to SATA III doubling the throughput. Again, at the time the drives where either fixed or had a jumper to alter the I/O speed.
Later improvements in Ethernet speed detection rolled over to SATA! A group of drives where introduced which offered speed detection! So the drive would match its I/O speed to what the system needed (we call these drives Auto Sense).
Many people mistaken this technology as being normal its not! You need to review the spec sheet of the drive to see if the needed I/O speed is listed. In this case the Western Digital Blue SSD is a fixed speed SATA III (6.0 Gb/s) drive unlike this drive Samsung 860 EVO SSD note the Interface line lists your systems I/O speed.
As older SATA I & II systems are being retired or no longer being upgraded these Auto Sense drives are not as needed as in the past.
Many drive makers are dropping this tech as it effects the price of the drive. So to be more competitive trimming away no longer needed technology is being done!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shrayes Raman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 124
