跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
Why is my Speedometer lights not working
I replaced my bulbs and my fuses for speedometer every other light works but that one and it’s still not working I really don’t know
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @ricky_walks2000 ,
Did you check that voltage was reaching the bulb when you replaced it?
Even though you replaced the bulb doesn't mean that there isn't a break in the circuit to the bulb from the light switch.
Assuming that all the other lights in the instrument cluster are working the problem must be in the instrument cluster.
You need to trace the circuit from the speedometer light bulb to the light power rail in the instrument cluster (power that is supplied by the light switch) and to the earth connection in the instrument cluster to check if there is an open circuit preventing the light from operating.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ricky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 118
