跳转到主内容
加入维修社区 - 创建账户
Trio Stealth G4 是由 Mach Speed Technologies 制造的一款平板电脑,配备 7.85 英寸高清触摸屏。该设备支持 Wi-Fi、蓝牙和 Google Play,特色功能包括四核处理器以及前置和后置摄像头。
Why is my trio 8gb not working
I need to known how to turn on my Android trio 8gb tablet if it won't turn on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @camogirl19 ,
Does the tablet give any indications that it is being charged when you connect the charger to the tablet?
If so this is good as it shows signs of life.
If the battery is charging allow it to fully charge before attempting to turn on the tablet.
Once it has fully charged try turning on the tablet with the charger still connected.
If still no good, disconnect the charger and using a straightened paperclip, press and hold the reset button which is located in a hole next to the headphone socket. You will feel the button operate when you gently insert the paper clip.
Hold the button operated for about 10-15 seconds and then release.
Check if the tablet now turns on.
Here’s an image which shows the location of the reset button.
(click on image to enlarge for better viewing)
DO NOT confuse the hole with the microphone hole at the other end of the tablet as you don’t want to damage the microphone by pushing a paperclip into it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Abigail Strong 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 19
过去 30 天: 37
总计 339
