跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Battery Replacement = Wifi Problems
I know this has been asked before and I’ve read through those posts and have not found a satisfactory answer.
This morning, I replaced my iPhone SE’s battery with one from Imilitis. This is the 6th iPhone battery I’ve replaced, but, the first time this phone has had its battery replaced.
I’m now experiencing WiFi connectivity / range issues. For example, I live in a small home, our router is upstairs and I am downstairs and the phone will not connect to either network (2.5GHZ / 5GHz). When I walk upstairs, closer to the router, voila.
In previous posts, people have mentioned that it was “coincidence” that the Wifi/Bluetooth antenna would fail / degrade at the same time. I call bullsh*t on that. I’ve watched the tear down videos to see if maybe I damaged the Wifi/Bluetooth module/antenna, but I really don’t think I did.
That said, there really isn’t any other explanation or fix, is there?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your an amatuer than most definitely you were using something too pry it out and slid upwards above the battery and tore into the wifi antenna. It’s a $3 part no biggie.
完成的
添加一条评论
2个答案
已选择的解决方案
Finally had the chance to tear into the phone and found that I broke the wifi antenna (the s-curve portion that connects to the logic board) during the battery change.
这个答案有帮助吗?
得分 0
添加一条评论
Maybe try resetting your network settings or a factory restore to rule out it being software related.
这个答案有帮助吗?
得分 0
1条评论:
Yep, tried that. Thankfully, the bluetooth still works, but Wifi is shot.
完成的
添加一条评论
添加你的答案
Kyle Petrozza 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 601
