The first few things you check for is Spark, Fuel and Compression, if you have spark, normally the crank and cam sensors are good along with any ignition items, plugs, wires, coil, ignitor. Hard to start is typically related to fuel pressure, if you cycle your key on a few times before trying to start, does it start up better?
由 Duane Donaldson 完成的
