跳转到主内容
The BlackBerry Key2 (stylised as BlackBerry KEY²) is a touchscreen-based Android smartphone with a portrait-oriented, fixed (not sliding) integrated hardware keyboard. The Key2 LE is produced by TCL Corporation under the BlackBerry Mobile brand name and is available in 3 colours. Includes models BBF100-1 (EU, Africa, AU); BBF100-2 (Canada, US, LATAM); BBF100-6 (ME, APAC, India); BBF100-4 (China).
5 个问题 查看全部
How do I fix an antenna broken off the mainboard?
Hi
During a screen replacement, the “male” part of this blue cable (i think it’s the antenna) did break off the mainboard (slot 2) and is is now “stuck” inside the cable.
How can I replace the “male” part on the mainboard? Do I have to solder? Because I’m not that experienced in solder tiny things so I’m kind of afraid to break even more.
The local smartphone doctor would charge me $70 for a repair - is that a fair price or way too much?
Kind Regards
Cedric
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
You can do a right repair: Find the broken piece and solder it back, or Order a new piece and solder it back, or take the piece from a donor board and solder it back.
You can do a quick repair: Remove the head from the cable, solder the outside cable to ground and the internal cable to the signal pad.
Is a five minutes task, but you need to have the equipment and the knowledge to complete the task. From $30 to $50 I think it’s OK
这个答案有帮助吗?
得分 2
4条评论:
I think this is horrible advice. “You need the right equipment…”. Yes! This is a microsoldering job, and if you muck it up, the motherboard is toast. I paid $150 to fix mine, at Microsoldering.com. This failure apparently happens often.
完成的
Agreed. I have soldered these u.fl connections. They are very small, difficult to solder. And easy to cause a short circuit.
完成的
@Bob Haberkost $150?????????? Jesus, I’ve soldered these on for £5 😂 Some places really take the mick.
完成的
guys, soldering antennas is stupid! I think I've already fed a few things in my 44-year-old life. this doesn't work - I fried the parts around in a few seconds - key2 written off - second attempt a couple of months later - conductive glue, then pour it hard in epoxy - the only option! all key2 have a huge defect in the quality of the male connector - before you start anything, it's better to stick it hard on the MB - it will save a lot of problems and worries
完成的
添加一条评论
添加你的答案
Cedric 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 19
总计 1,300
