iPhone XS Max randomly reboots (only when used)
ey guys.
I have an Iphone xs max which reboots randomly when used. If I go into youtube and play music after 5-6 minutes it reboots. If not used it reboots rarely. I didn’t have this problem before.
I get two kind of logs:
panic-full-2019-11-22-030600.988.ips
panic-full-2019-11-18-161110.867.ips
https://drive.google.com/open?id=1CxZCwQ...
https://drive.google.com/open?id=189QG1N...
and no I don’t have warranty…
what is the exact problem? and how do I analyse these panic-full logs?
Have you at any point had a rear housing replacement or had the charge port changed in the device?
由 Jade Richards 完成的
Yes.
At some point I cracked both sides, the problem started at that moment.
I thought it was due to the screen which had a lot of green lines and didn't work. After changing the screen it still happened, but at that moment i had already ordered a housing with everything pre-installed, which i naturally mounted.
由 Abdullah Kacar 完成的
Tried to put a original charger flex but nothing has changed.
As I had the same problem with changing the rear housing of an iphone xs and had to swap all the small parts with the ones from the original phone and after that had worked and found it was the power flex in the small parts housing was shorting it.
由 Jade Richards 完成的
Is it possible to unplug some of the flex and run the phone to see if that is the problem?
