One trigger activates both
sometimes when only the left trigger is pulled both triggers will activate I have attached pictures showing both controller and ‘xbox controller tester’ app to illustrate,
happens most often after right trigger has been pressed lightly. momentarily clears if the right trigger is quickly fully depressed and released. opening the back of the controller revealed no obvious defects.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
