跳转到主内容
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
570 个问题 查看全部
Can fall damage cause lag?
My playstation fell of my desk from about 2ft to a hard surface. While upon inspection, nothing appears to be physically damaged. The only issue is I occasionally have high ping while playing games and some games tell me i have no network connection at all even when connected to wifi. Should i have it looked at by a professional?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Fall damage doesn’t correlate with high ping. Ping can be affected by so many things. Have you tried plugging in directly to your router and see if that fixes anything? To me it sounds like you have a weak connection to your wi-fi. Maybe try moving your router closer to your setup and see if that fixes anything. Dealing with high ping is annoying and frustrating, but i’m sure you will figure it out. If there was damage it would either work or not, no really in-between. You could try opening it and unplug and plug in the wifi antenna cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Damon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 220
