跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
197 个问题 查看全部
"Fusion" or "RAID 0" PCIe SSD to SATA 3?
OBJECTIVE: Create the fastest Mac Mini ever by either Fusion or RAID 2 SSD’s.
HARDWARE: 512GB Samsung PCIe (Apple SSUBX '''blade) and 512GB Samsung 2.5 ('''860 EVO Pro)
DILEMMA: I have never seen either done. Is there a reason other than cost per/GB?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
RAID setup require two interfaces (same) and drives which are running at the same I/O speed. Thats not possible in this series! Here you have a PCIe/NVMe interface and a SATA interface.
Fusion Drives are a compromise! Leveraging the SSD as a cache to the slower HDD. Thats why the SSD’s Apple uses are on the small size. Using slightly larger SSD’s can be helpful at some point the benefits drops like a stone and the costs become wasteful!
The best you can do here is setup a dual independent drive config! Get a 500 GB or larger PCIe/NVMe blade SSD set it up as your boot drive hosting your apps. Leave the rest of the drive empty so the OS can leverage it for virtual RAM, caching & paging. If your apps use scratch space make sure its setup to use the SSD. Use the HDD as your data drive. If you need to upgrade it consider doing with a SSHD drive. Going with a 2.5” SSD doesn’t offer any true benefit in this config given the cost.
References:
The Ultimate Guide to Apple’s Proprietary SSDs
Seagate FireCuda 2.5” SSHD
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
applerepairshop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 163
