跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
after battery replacement, home button nor Touch ID works
I Replaced a screen on this particular IPhone 7 Plus with no issues , Then it needed a battery replacement. Replaced the battery and now i have no home button nor Touch ID. Any help would be greatly appreciated. Everything else works with no issues.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
So you transferred the home button to the new screen and reassembled the phone and the home button and touch ID was working. Then you removed the screen again to replace the battery and now the home button is not functioning.
There are two possible causes.
·         Check the home button connector is seated on the logic board correctly.
·         Check for a tear in the home button flex cable. (The one that goes from the screen to the logic board) You might need some magnification to detect it. This is the most common problem.
这个答案有帮助吗?
得分 3
添加一条评论
This post should help you out on the issue, they did a very good job on explaining it too.
iPhone 7 home button not working after screen replacement
In my view you may have damaged something when you replaced the battery. You should take the device apart again and see if you put the ribbon cable in correctly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Justyn Thornton 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 444
