跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36476 个问题 查看全部
iPhone 8 home button issues after Screen replacement
Good evening!
recently completed an iPhone 8 screen replacement to which went smoothly until noticing the home button only half works. Being that the Touch ID works however it doesn’t respond to being used as a back button.
it was not an issue with the damaged screen as I did happen to test it. But after removing the damaged screen i can’t use it to test the home button. I’ve inspected the home button and can’t see any tears in it what so ever and I’m also aware of ensuring to use the right size screws. I noticed before placing the new screen into the actual phone the home button did respond to the click and did work as a home button but once I fully assembled the iPhone it simply wouldn’t respond to being used as a back button.
i’ve taken it all apart around 10 times and the best result I get is that it works for around 10 seconds of the phone being on and then it simply only responds to being used as a Touch ID.
just to clarify
the home button did work before replacing the screen
i understand that it only takes a small tear however the button still responds to a fingerprint
im aware of ensuring the screws go into the right screw holes
ive ordered a new screen as I believe there may be a slight chance it maybe a defective cable on the screen.
just wishing to see if anyone else has had this problem? If so what steps where taken?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If the touch ID functions correctly I would be looking at the turtle IC. It might have got nudged during the transfer. You could try another screen but when there is a tear and or bad flex from the screen it usually disables the touch ID as well.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Beau Clarke 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 96
