跳转到主内容
加入维修社区 - 创建账户
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
Why won't my 3ds turn on?
So, a few days ago i found my old 3ds that i haven't used in about a year. When i pressed the power button initially, the screen lit up and the 3ds turned on. But the battery was low so I turned it back off and put it on the charger, and it seemed to charge fine. The orange light came on and everything. Since then, I haven't been able to turn it on at all. I've pressed the power button in pretty much every way possible but nothing ever seems to work. I tried some steps i saw on the internet but they all failed to solve the problem. Does anyone know what might be the cause?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You may need a new battery. Batteries tend to wear over time, that could be the problem.
You could also try removing the battery and with the battery out, hold the power button for 10 seconds, put the battery back in and check.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Slim Swivel 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 7
过去 30 天: 27
总计 4,734
