跳转到主内容
iPad Mini 4 发布于2015年9月9日,有着类似 iPad Air 2 的性能和更小巧的身材。
What is this component?
Replaced the screen on this iPad mini 4 some time back and the iPad never worked again.
It doesn’t power on, no back light or sound and doesn’t cause Windows to detect a device on USB. Hooked into a USB ammeter and it shows 2.15A at 5.03V. Battery disconnected it’s at .08-.15A.
Threw it under the microscope and removed the protective cover around the display connectors and noticed something that looks like it might be damaged. I don’t have any schematics for the Mini 4 and don’t normally do phone / iPad board repair and don’t have ZXW, so I’m looking for a little help on this one,.
Component is just to the left of the larger display connector when the lightning port is up.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I updated the images. Anyone have any thoughts about that component? It looks like it blew up, but there's no signs of any damage in the area. This board has never been worked on.
完成的
添加一条评论
1个答案
it looks like a blown cap but under my scoop it looks more like a diode, pull one from a donor and if you replace it see if it fixes it
这个答案有帮助吗?
得分 0
2条评论:
I don’t have a donor, do you have any idea what the value might be so I can try and find a replacement component? Thanks for taking the time to answer :)
完成的
no clue but if it is a cap there is a good chance you can remove it and leave it off and itll work if its a diode it probably wont work though
完成的
添加一条评论
添加你的答案
Troy Siedsma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 110
