跳转到主内容
Ability to convert from laptop to tablet, tent or stand mode with hinges on the side. Released January 2014.
37 个问题 查看全部
USB ports are not working
They stopped working after I connected some bracelet charger and power pins got in contact (short circuit), Laptop gone off and when I power it back none USB works, I tried everything, all software things and removing battery and putting it back.
I guess some USB chip is dead?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @nemanjam291,
More likely you blew the power supply circuit that is supplying the USB ports.
Try connecting a USB mouse or any USB device that shows that power is being supplied e.g. red laser light on USB mouse or mobile phone indicating it is being charged.
If there is no indications then the power is not there.
Open the laptop and check if you can find the motherboard board number.
Once you know that, search online for a schematic for the motherboard using the board number only e.g. search for (insert board number) schematic or perhaps (insert board number) wiring diagram.
If you’re lucky and one is available online it will be of great help in locating and repairing the problem.
Here’s a link to the laptop’s hardware and maintenance manual that may help with gaining access to the motherboard.
If this seems too daunting, contact an authorized Lenovo laptop repair service and ask for a quote to repair the laptop, as they may have access to the schematics etc if they aren’t publicly available.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Nemanja 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 17
总计 1,008
