跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 screen very dim. Backlight IC or Backlight filter?
Hello there so I have a iPhone 5 that I repalced the screen and the new screen is very dim. Is it the backlight IC or the backlight filter? I stupidly reseat a the old screen with the battery plugged in it didn’t fry the logic board but it did fry the old screen and the backlight filter or ic.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Could be both but usually it is just the filter that blows as a fuse.
这个答案有帮助吗?
得分 3
2条评论:
I could try replacing the ic and the filter.
完成的
Check the contenuity on both sides of filter. If it's too high in ohms or O.L the filter is blown. Replace that first test then work from there.
完成的
添加一条评论
I also have another problem the rear and front camera stopped working the camera app just have a black screen 3rd party app also doesn’t works
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adi Malikul 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 54
