跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
Sound adjustment rocker bar missing
I gifted my old 3G to my grand daughter. She was able to shatter the front glass and somehow, either in that process or in another removed the rubber like sound adjustment bar from the side. Replacing the glass and digitizer is doable and inexpensive, but I can't find any reference to how to repair the sound rocker switch. I haven't yet taken it apart, there's just an empty slot where the rocker used to be. I had taken this unit apart and put a new battery in it about a year ago so I'm not afraid of doing the take down.
TIA
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
That switch is actually attached to the iPhone Back Assembly and is pretty hard to fix without replacing the entire back assembly itself. You could try buying a new button and superglue it back on, however there are many things that could go wrong with that (putting too much glue on and rendering the button useless all together with possibility of glue leaking inside the assembly and damaging the ribbon).
If i were you i would just buy a new back assembly and be done with it. They are fairly cheap and easy to install, and if you have already replaced the battery once you will know how to do this easily.
You will want to buy the "Back Cover Assembly " to save the hassle of installing all of the components that go into the assembly itself. A quick google search should find you a decent price.
Hope this helps! :)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
dheady 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 700
