跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
iPhone 8 Touch ID not working after battery replacement
Hi, I replaced the battery on my iphone 8 and did a hard restart but I got an error message that Touch ID was no longer working. Also, the home button does not work. I checked all of the connections again and same thing. I put the old battery back in and everything works fine. Tried the new battery again and same error. I didn’t replace or disconnect the screen / home button or any other parts.
I’ve tried restarting several times and playing with the options but no luck so far. Any ideas? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Check (Really Close) the Home button flex cable remove the protection to see it better, also check Screen flex cable, if you dont removed the screen while you were removing the battery you can damage easily the flex cable. If you cant see anything post a picture, may we can help.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Jeff Lyons 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 238
