跳转到主内容
Repair guides and support for the OnePlus 5T, an Android smartphone with a 6.01" AMOLED display. Released in November 2017. Successor to the OnePlus 5. Model number: A5010.
35 个问题 查看全部
Oneplus 5T - Motherboard FPC pin Problem!
I've had this oneplus 5T where I cracked its screen(intentionally… /face-palm), tried fixing it myself, ended up in a total failure and this is how I ended up damaging the motherboard pin, where the USB cable connects.
Now I took a calm approach, and want to fix it again, I have all the necessary tools, but I have 0 soldering skills, so please check the images, and tell if it's possible, and give me some guides or something… thank you
Here you can see the torn pin
Torn part from the pin
Here I cleaned up the area
This is the new pin I've ordered
And here are the Tools I have
Is it possible to fix this??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
If someone have a dead oneplus 5t I would like to try to change this fpc connector practice make men perfect so if anyone have fully dead phone or motherboard issue let me know will try fix it. If it gets fixed it’s free for you.
完成的
have the same issue. Where have you found the parts..?.. which website you buy FPC connector..?
完成的
Hey were you able to fix it finally.
I screwed it up the same way.
Please mail me inorockdude@gmail.com. truly will appreciate it
完成的
添加一条评论
3个答案
最有帮助的答案
100% That is possible to fix, practice in another phone for parts, if you purchased all that stuff you can purchase a phone for practicing. Until you do a clean job you can do it on your good phone.
With a Soldering pen with angle on the tip and enough flux you can do a good job.
这个答案有帮助吗?
得分 1
5条评论:
@conlledo This was my main phone 2 years ago, now I want to resurrect it, I've watched a lot of guides on this, and I will try and do it on this phone, with extreme patience.
I dont have have the Flux from my bag of tools but I've already ordered it, and also waiting for the pin to come, I will definitely give an update soon.
完成的
Find a board, any old board (Computer, Toy etc) and try to remove and put back components that helps to know your soldering pen. also does the soldering pen has temperature control?
完成的
That's a very good tip, and yes the soldering has a temperature control, 300 and something should be used from my understanding, no?
完成的
That you see the FPC is a plastic piece, and if the tip is too hot you can destroy it, so you have to choose the right temperature and right tip to complete the job.
完成的
Did it work out? I have the same issue. Where have you found the parts?
完成的
添加一条评论
I've had only problems with this phone, mine was never the same, I repaired it, I've sent it to oneplus for a trade in Programm and they never responded back…
To answer your question, I found it on a UK website but it costs 16£…
To give you a friendly advice, never settle.
这个答案有帮助吗?
得分 1
1条评论:
would you please provide me with the website that you got the FPC from? i am facing the same issue and couldnt find the chip. my email is bilal.haji@gmail.com
完成的
添加一条评论
Bro pin kaha se mile
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Macarovici Dan Andrei 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 1,362
