跳转到主内容
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
Why won't my system menu show up?
I turned off my ps3 and went away for a night. I get back, I plug it back in and the system started up and after the "ps3" logo disappeared, the sparkly floaty wave just stays there and it won't go to the system menu and my controllers won't connect.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I have this problem. When PS3 boots up it says ps3 and photosensitive epilipsey then it lags!! I am so worried!!
完成的
添加一条评论
1个答案
已选择的解决方案
My Answer To Another Question
Boot the system to the recovery menu, and restore it manually. However, there's a chance that all data on the system will get wiped, so keep that in mind. Boot it to the recovery menu by turning it off, then holding the power button down until it has beeped three times, and shut down. Then hold the power button down again until it beeps twice and then double-beeps. A message should come up on the screen telling you to connect a controller with a USB cable. Do so, then select "Restore Default Settings." When the process completes, reboot the console, then boot it to the recovery menu again and select "Restore File System." Reboot it and boot it to the recovery menu one last time, and select "Rebuild Database." Reboot the console, and see if it boots to the XMB (Home Screen)
EDIT:
The Recovery Menu Will Look Like This:
这个答案有帮助吗?
得分 3
9条评论:
Will that delete my game data and downloaded content?
完成的
It has the potential too, I've never used it on a console with any data on the hard drive, so I'm not sure. Before you try that, just use the "System Update" feature of the menu, and reinstall the system software. That won't delete any of your data.
完成的
The problem is I can't go to the menu.
完成的
My model is a 80 gb ps3 preowned from gamestop.
完成的
Can you get to the recovery menu that I talked about in my answer? You need to do the system update from there.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Nicholas Villarreal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 7,195
