跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 个问题 查看全部
My iPad is stuck on "Press Home to upgrade"!
Hello guys! So I need some urgent help with this little problem.
I had set a password for my iPad a while ago, and when I got it again, I couldn’t remember the password at all. As stupid as I am, I tried too many times, and I got the “iPad is disabled, connect to iTunes” screen. I manually installed the firmware for the iPad, and I updated my iPad software through iTunes on my PC. When it was done, I was met with a screen that said “iPad is disabled, try in 60 minutes”. I waited, but then a white screen showed up, and at the bottom, it said “Press Home to Upgrade”. My iPad home button is broken, and AssistiveTouch wouldn’t work either. I tried to connect my iPad to the computer again, but the computer is not recognizing the device.
Have I lost all hope of ever fixing my iPad, or is there still something I can do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you want to attempt recovering data / information from the iPad you need to get that home button fixed.
Otherwise you’ll need to manually install the firmware with a DFU restore which will at least let you re-use the iPad like it was new. You can re-enable assistive touch via 3utools with the enable assistive touch option under accessibility. iTunes also allows you to do this too.
这个答案有帮助吗?
得分 4
2条评论:
The problem is, the PC cannot recognize the device that has been plugged in. Any suggestions?
完成的
Yeah you'll need to fix the home button to get past the press home to upgrade option.
Can't really force restart an iPad with a broken home button unless you open up the iPad and disconnect the battery.
完成的
添加一条评论
添加你的答案
Apple Lover 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 49
总计 1,982
