跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
oh no please help my iPhone 5s volume button does not work
Hi i have a big problem or so i think. my IPhone 5s volume button does not work it clicks fine and everything seems fine with the cabel any ideas how i can fix this? btw i just changed the screen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Try turning on the Assistive Touch.
While this won’t actually fix your problem it gives a temporary solution that allows you to adjust the volume of your iPhone. You simply go to
Settings>General>Accessibility and turn on Assistive Touch.
If you try to tap the volume buttons they may work after a while. What I believe you may have to do is re-seat the cables and try putting the phone back together. It is possible one of the cables may have been damaged during replacement or it could have been a defective part if everything went smooth. Not uncommon with some places but I wouldn’t rule out damage either.
这个答案有帮助吗?
得分 2
1条评论:
Hi thanks i will try does stuff but i did not reaplace the volume button. i take a look again if i can find anything.
完成的
添加一条评论
添加你的答案
Bertil II 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 104
