跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
Front camera not working after switching logic board
First off the phone was iCloud locked. So I then purchased an iCloud unlocked logic board. I replaced the logic board to the unlocked one. I put everything back together perfectly. It turned on and functioned perfect all around but the front facing camera. The rear camera works perfect, but when I switch to front facing, it’s just a black. Anyone know why this has happened? Please need help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Often this is caused by a wrongly seated connector. otherwise perhaps the complement was damaged during repair and you will have to replace it. Unfortunately I don’t think Face ID works when it’s replaced
这个答案有帮助吗?
得分 0
1条评论:
I double checked everything and al the connections are connected properly. The rear camera works but when I switch to the front camera it doesn’t work at all.
完成的
添加一条评论
添加你的答案
manditotrevino69 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 248
