跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
Apple Pay not working after frame replacement
I have an iPhone XS. Until recently had original but broken screen and rear glass so I decided to replace them. After moving all the parts over and rebuilding everything works as it should apart from Apple Pay. I’ve been able to add / remove cards etc but it just says hold near reader and doesn’t recognise that one is nearby. I have tested wireless (WiFi), cellular, Bluetooth and wireless charging are all working just not Apple Pay.
From searching online I’m unable to determine exactly which parts I should be looking at to get this up and running again?
any ideas ?
Thanks!
Charlie
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hi did you ever manage to fix this issue , I have got exactly the same issue at the moment . Thanks
完成的
way late response, but for anyone stumbling by here, Apple Pay uses NFC, the XS has an antenna which is for NFC and bluetooth. Try reseating it and/or replacing it.
完成的
Same case here with apple pay not working after changing front and back covers
完成的
添加一条评论
3个答案
最有帮助的答案
You likely either damaged the NFC antenna, or installed it into the new frame incorrectly.
While iFixit does not have a guide for the NFC antenna (or other, more difficult internal components), you can see it in the top left corner on steps 13 and 14 of the teardown guide. iPhone XS及XS MAX拆解
In fact, at the end of the teardown it is still in the phone, never removed, meaning iFixit's own staff never removed it from the frame as part of the full teardown.
When doing a full frame replacement, this antenna is delicate. It is glued down to the frame and very easy to tear or damage during removal and reinstallation. It is one of the very last things you can take out of the phone, requiring you to take out most other components before you can access it. Additionally, all of the screws serve as grounds for not only the NFC but also other components that use the same screw holes.
The above is an image of the antenna. If you lost any of the screws that hold the antenna down, or if you layered the parts the wrong way, you could have simply not grounded the antenna correctly and it will not work. It could have easily torn (even just a little bit where you did not see). Or, finally, it could just not be plugged in correctly. Sometimes it is such a small part and so tucked into the corner of the phone that people do not even recognize they need to transfer it over.
Consult this image to find your antenna in your phone. Verify it is in good condition, and make sure all the screws are layered correctly (i.e. such as the NFC screw hole directly against the frame, then the screw hole for <other component(s)>, then the screw on top, with any standoff screws in the middle properly as needed.
Apple intentionally makes these things needlessly complicated, complex, and difficult to repair properly. They give an unnecessary amount of screws of different sizes and shapes and types and they design their parts easy to accidentally damage during user removal and the ground specifically to short and not work properly if it is not done precisely correctly according to Apple's specifications. Do not feel bad if you messed it up, the NFC antenna is notoriously one of the hardest ones to get right on a full frame transfer.
这个答案有帮助吗?
得分 1
添加一条评论
It’s could be the NFC antenna. Try replacing that and go from there.
这个答案有帮助吗?
得分 0
4条评论:
But which part exactly is that ? I couldn’t determine whether it was part of the charging coil, the flex cable at the top right, or one of the smaller brackets...
Thanks
完成的
Anybody? Been a few days and short of tearing my device again I’m still lost :(
完成的
I’m not 100% sure but I think it’s something to do with the power button cable. You can probably find a tear down guide online
完成的
Did You manage to solve the issue, i have exact same problem
完成的
添加一条评论
Does Wirless charging working? If not, NFC antena, thats all. Check conection and how it look after this replacement, there shouldnt be any scratchers on the nfc tape.
这个答案有帮助吗?
得分 0
1条评论:
wireless charging still works but nfc does not, any qlue?
完成的
添加一条评论
添加你的答案
Charlie S 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 24
过去 30 天: 75
总计 2,221
