Xbox One continues make noise
My Xbox One continues to make noise when turned off, how do I determine if its the fan or disc drive. Unit works otherwise concerned about fire.
When you turn it off the system goes into a sleep mode that allows it to maintain game progress as well as application data. This in turn will keep the system active for a little while after shutdown.
If you don’t want it to persist you can change this in the system settings to do a full shutdown instead.
Another way to ensure a full shutdown manually, you can hold the power button on the xbox itself until the light goes out and you’ll be able to hear everything come to a halt, but this is overtime harmful to the system OS and memory.
Best of luck!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 24
