跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
368 个问题 查看全部
Why is my ps4 turning off when I start a game
Earlier today I was playing fortnite because I recently wiped my ps4 because of crashing and on reddit people were telling me to and then I got off because textures weren’t loading the entire time so I went into safe mode and rebuilt data base (another suggestion by reddit users) once I was done with that it was working fine and I had the same issue with textures so I got off and now when I turn it on Netflix is only working every time I try to get on a game it starts the loading process and then the screen goes black and the light bar on the ps4 stays white for about 10 seconds turns off the ps4 and then it brings me to the screen as if I unplaced my ac power cord. This issue keeps happening and I need an answer. Please and thank u to anyone willing to help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
This just happened to me how did you fix your problem
完成的
Same I hate this $@$*
完成的
Me too what the f@#$ why is this all of a sudden a &&^&^$^ thing
完成的
I got the same f.ckin problem dude
完成的
添加一条评论
3个答案
最有帮助的答案
It is possible that the fans aren't working properly. Make sure no fans are blocked and if possible take a compressed air canister and use it on the fans, or just use a vacuum cleaner.
这个答案有帮助吗?
得分 2
2条评论:
I s cleaned it yesterday and it only happens sometimes @johnodon
完成的
Have you replaced your power adapter (the thing that plugs into the PS4)? If this helps please mark this question Answered
完成的
添加一条评论
guys forget about rebuilding your data I just tried this and it worked the first time just run your fingers through the sides of the ps4 and the back to get the dust out then just blow on the fans to make sure there’s no dust then start it up and fortnite will work
这个答案有帮助吗?
得分 1
2条评论:
if it's the fans and dust causing the problem then how do other applications work well? I have the same problem with fortnite and i'm trying to look for answers.
完成的
@not75things Hey yes I’m having the same issue as well, fortnite turns off my game when I try to load it up but I can open other applications and games on my ps4 and it doesn’t turn off. did you find a solution to your problem.
完成的
添加一条评论
Yup this is happening to me as well since the new update I don't know why I can play any other game perfectly fine. Grrrrr
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
BrownyM16_ Gaming 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 68
总计 10,141
