Write protected pendrive issue
my pen drive has been write protected, format related issue.
I did everything like in registry edit, cmd command, used tools, but the problem remains same
First I maked the bootable USB of Ubuntu then I installed Ubuntu in dual boot successfully, but now I am formatting my SanDisk USB then it is showing me error of " write protected". I tryed most of the ways from Google but that is not working, my USB is also showing in disk manager but, I am not able to format or delete the partition, can you help me please 😢🙏
这个答案有帮助吗?
Download Ease partition primary
And click own write protection clean
It will scan usb and clean its write protection problem
这个答案有帮助吗?
Possible causes of read-only mount:
这个答案有帮助吗?
Its seems that Cruzer Blade usb disk is awful. I have the same problem “write protected” and I have found many other posts in internet with the same problematic usb disk.
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 113
总计 4,517
2条评论
Have you attempted to use any kind of write protection removal or partitioning tools?
由 Jacob Mehnert 完成的
usb write protected problem
由 MEGERSA TEMESGEN 完成的
