How to disable hall sensor
I’ve got an early 2015 MacBook Pro 13” that has a bad hall sensor and is randomly going to sleep. I have previously found out on an other forum I made that the hall sensor is soldered onto the logic board so my original plan to just remove it will not work. I’ve got InsomiacX running and does a decent job of stopping the issue but the system will still try to dim anyway and when it does that it stops taking input from peripherals. I was wondering if there was a way to disable the sensor altogether in software?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
