跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
Restoring via network recovery. Corrupted info. on recovery server?
Trying to restore operating system on Mac OS Sierra and using network recovery option. After it verifies it says “The installer information on the recovery server is damaged”. Top recommendation is to download the macOS Public Beta Access Utility. Is this still available and has anybody had any luck with this method? Any help is appriciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Looks like Apple failed to update the recovery server images! Apples certificate expired!! Here’s more If you've got an old macOS install image, it will probably stop working today
Here’s the needed image file How to upgrade to macOS Sierra Jump down to Step 4 for the download.
这个答案有帮助吗?
得分 2
5条评论:
Chose to upgrade to newest compatible OS, Option-⌘-R on startup, instead of restoring and seem to have dodged a bullet. Thanks for the pointers, Dan.
完成的
Yes, you are lucky! What are you running now? Did you bump it up to Catalina?
完成的
@danj Yep, wiped drive and then updated to Catalina.
完成的
@haroldcantlie is it safe to wipe up drive and then update to Catalina ?
完成的
@Irshad Ahmed - Yes, you'll want to reformat the drive. But you should make a bootable OS installer thumb drive following this guide How to create a bootable macOS Catalina installer drive
完成的
添加一条评论
shutdown iMac / hold option/command & R keys down on keyboard & restart the iMac.
go into MacOS Utilities / select Disk Utility / select the top HDD in the list on the left / CLick ERASE / then SHUTDOWN again / (repeat the same startup process) hold option/command & R keys down on keyboard & Turn on the power to the iMac WHILE holding the keys down until the MacOS Utilities comes back up. NEXT / select REINSTALL MacOS /continue… then follow the prompts and BE SURE to select the same HDD that you previously formatted before you restarted the iMac. .. this will download the new Catalina OS .. it will take a while… I just did this myself while on the phone with Apple Support… and it worked.
P.S. it's best if your iMac is plugged into a network jack and not on wifi .. but wifi will work just as well but a bit slower.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harold 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 20,351
