Finder keeps relaunching?
After changing the language settings so that I could type in Japanese etc. when I restarted the computer finder would keep relaunching itself. Any ideas as to why this might happen?
Did you use any of the delocalizer programs that are available? You might have removed the language packs. I'd try an archive and install using the original OS disk. Once that is complete, re-apply the updates. Once you're satisfied everything is working, you'll need to re-add any printers and delete the Previous Systems folder in the root of the hard drive.
这个答案有帮助吗?
Reinstalling the OS would definitely work, but seems like a last resort. I wonder if reinstalling OS X over the top (without an archive) would do the same thing. Or just installing Japanese language support from the extras in the install disk.
Kyle, There are only 3 options. Install (Upgrade), Archive&Install, Erase and Install. An archive&install takes about 45minutes(ish). If the finder is crashing it's difficult to install the language packs.
In the past, this has been due to an old version of Stuffit. Try either updating to the latest version (search on "stuffit" at versiontracker.com), or uninstalling. A simple delete probably won't work, you need an uninstaller.
这个答案有帮助吗?
I would try and do a permissions repair for a start. ( utilities / disk utility ) then reboot .
If that fails it could be a corrupted language in the system. Try reselecting English as the primary language. Reboot the system and see what Finder does. If Finder returns to normal It's a corrupt language and I would suggest reinstalling the OS.
This should then solve the issue
这个答案有帮助吗?
I've encountered this problem twice, and both times it was Stuffit that was causing the problem. Did a complete uninstall and problem solved. Check Activity Monitor to see if anything is hanging up...
这个答案有帮助吗?
This is definitely caused by STUFFIT. Don't remember the fix, but found answers online.
这个答案有帮助吗?
Hi guys!
I had this problem on Mavericks today and spent 4 hours dealing with it. I have tried EVERYTHING:
nothing helped.
But, eventually, I saw the post in Google groups, and it solved my problem. Solution is to obvoius.
GOOGLE DRIVE WAS THE PROBLEM. Indeed, Google Drive very closely works with finder, and, as I suppouse, at some point they had conflict, which made finder relaunch all the time.
So, I quit GoogleDrive and even without restarting Finder started workiking normally.
P.S. I was even ready to buy external drive to make backup and make clean install.
Hope, it will help you!
这个答案有帮助吗?
Or, keep google drive opened and turn off "Show file sync status and right click menu" on the gdrive preferece panel
P.s. )'m currently on mavericks 10.9.5
过去的24小时: 0
过去的7天: 0
过去的30天: 6
总计 4,607
