跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
331 个问题 查看全部
Trouble removing charge flex cable
Hi, i’m having a difficult time removing the charge flex cable that is soldered to the board. I’ve watched several videos but always end up ripping the pads off the flex cable when trying this on a couple broken ipod boards i have. I’ve tried using my cheap hot rework station set to 250c and also soldering iron and adding flux then using wick to remove the solder but still can never get the soldered pads to lift off the board without ripping.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Is a delicate job, in my case i use only the soldering pen and a lot of tin. But even more easy I just change this part, or you can transfer it from the new one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 31
