跳转到主内容
Simple to use 35 mm manual focus SLR camera. Model number X-370.
27 个问题 查看全部
I can’t see through the viewfinder?
I bought my minolta x-370 online. when i got it, i could see through the viewfinder but the lever was stuck so i figured it needed new batteries. i got new batteries for it, put them in, and i tried to take a picture but something happened and now i can’t see through the viewfinder and the lever is still stuck.
does anyone know why this is happening? is something broken?
Update (11/03/2019)
I could see through the viewfinder just fine before I added new batteries. Now all I can see is black and the mirror won’t stay down.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Take the lens off do you see the reflex mirror up or down?
完成的
the mirror is up @danj
完成的
添加一条评论
1个答案
最有帮助的答案
Carefully pull on the mirrors edge ever so slightly! To test to see if the foam cushion got gummy which is now holding the mirror. Don’t pull more than a millimeter or two as you could damage the mirror linkage.
If that don’t do it you’ll need to find a camera repair person who has the skills to pull the mirror cage as the linkage or the electromagnet has a problem. This is more than a DIY job.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
hayley louis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 40
总计 1,285
