跳转到主内容
加入维修社区 - 创建账户
The Gateway FX6840 is a desktop PC that features an Intel Core i7 processor.
Windows 10 won't boot due to drives converting to RAW format from NTFS
How do I convert RAW drives back to NTFS without losing data. Windows 10 repair options during reboot can’t fix. Only access is through the comand prompt. Have not tried diskpart option to convert to NTFS because of worry that I will lose data. All three partioned drives have all been converted to RAW format!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If I am not wrong, RAW format on Windows means that is part of a Software Array or Dynamic Disk Array. If you can see your information on CMD backup your information to another drive and make a clean installation.
If a drive is bad and is part of an Array you have to replace it and rebuild the array. If everything has been made with windows you can try to boot from another hard drive with windows and see if you can rebuild or backup your information.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
David Spear 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 437
