跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Ear speaker doesnt work
Hello everyone, recently i have changed battery for my iphone 3gs, i connected all the ribbons like it said on the instructions, everything works perfectly exept... the ear speaker. Could anyone help me please. Thanks in advance..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This is most likely a loose connection. Either that or you have damaged the ear piece receiver ribbon connector/connection during the replacement.
Below are some images of what the connections should look like.
The most common cause of an earpiece receiver not working is this cable coming loose.
This is the ribbon and connections by themselves.
MAKE SURE to push the small white tab down or the cable will come loose very easily.
If you have damaged the connector then it will look something like this, and unless you are a very skilled solderer then it is unrepairable.
Hope this helps! :)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
parulisv 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 623
