跳转到主内容
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
How can I get DS/3DS games clean and read properly?
I have a lot of DS games with a lot of hours played with. Sometimes when I try to play them on any DS or 3DS device the game won’t read. I have to pop it in and out or blow on the cartridge’s contacts with an air compressor. Sometimes I just try to wiggle it out a bit. The DS/3DS works fine with newer game and as well as the older games themselves. I want to know if there is a better way to clean them and get them to work probably from just slotting it in one go. Eventually in time I’ll have the same problems with the 3DS and Switch cartridges.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
5个答案
已选择的解决方案
Rubbing alcohol will do the trick! Just get a Q-Tip and clean the contacts of the cartridge!
You could try cleaning the game card port but be cautious about it. The best way to clean that is with a can of compressed air to blow all the dust and stuff.
这个答案有帮助吗?
得分 3
2条评论:
I used some paper towels and had it wrapped on a small flat head with a dab of pure isopropyl alcohol. It took a while genttly rubbing the contacts without breaking the brackets in between. In the end it got the job done and the games are reading again on the first inserts.
完成的
It did not work for me
完成的
添加一条评论
I would also NOT blow into your console or on the cartridge. Though it may seem silly small bits of spit and moist get on the metal contacts and can CORRODE the contacts! No fun!
This was debunked with SNES games. Actually taking out the SNES cartridges and putting them back in sometimes allows the contacts to have a better fit and then read. Blowing did nothing, it only corroded and hurt the cartridges!
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
folding a piece of paper 2 times and putting a little peroxide[i recomend 10%] on the paper and putting the piece of paper in the slots does it
这个答案有帮助吗?
得分 1
1条评论:
it did not work for me
完成的
添加一条评论
I used a eye glass cleaning cloth folded to get into the thin spaces. Worked beautifully.
这个答案有帮助吗?
得分 0
1条评论:
I do not have proper materials
完成的
添加一条评论
My minecraft new nintendo 3ds edition cartridge will not work. I tried every tip I could find but not one works. can anyone suggest some?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Gaitan 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 108
过去 30 天: 584
总计 50,913
