Would a 2015 13" MacBook Pro battery be compatible with a late 2013
Would a 2015 13" macbook pro battery be compatible with a late 2013 a1502 13” macbook pro. Thanks
The A1502’s from 2013-2015 use different model no batteries A1493 and A1582. They are both cross compatible. But if possible try to match the battery model number.
I’ve used vice-versa and it has worked either way.
这个答案有帮助吗?
Alright thanks, I've got a 2013 a1502 that arrived with no battery. Is there anyway to figure out which one it had? Thank you
That one used the A1493 battery. Getting the a1582 battery is a better choice as the battery cells will be newer and better than a battery that was made in 2013.
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 410
