跳转到主内容
Seventh generation laptop released in 2015. The Alienware 17 R3 is a high performance gaming laptop.
Why I cant connect to gmail?
I was having alot of problems with my laptop now . I cant access to any things but i was connected to wifi . I have tried many methods but none of them works for me. For example , i can’t connect to gmail , i cant download anything in microsoft store , and i cant even drag an image to here . LOL . ERR_SSL_BAD_RECORD_MAC_ALERT , 0x800704cf and more things is stopping me . HELPPP PLSSS
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi CKStereAngel
What had you tried? just it happened recently?
I have a feeling OS might be corrupted.
check hard disk health if possible.
if possible, you can consider on SSD drives too.
Try doing backup of your data and do a clean install of OS.
I suppose you are using win10.
suggest you yo download the usb installer tool from microsoft, format and reinstall.
once the computer running well, suggest you also check for any bios update on your laptop.
这个答案有帮助吗?
得分 1
添加一条评论
May be because of DNS overload or server bugs. Take help of google or any troubleshooting blog post.
这个答案有帮助吗?
得分 0
添加一条评论
It sounds like your laptop has deeper network stack or driver issues. Try these steps:
  1. Reset your network settings (Settings > Network & Internet > Advanced network settings > Network reset).
  2. Uninstall and reinstall your Wi-Fi adapter in Device Manager.
  3. Run sfc /scannow In Command Prompt as an admin, to check for corrupted system files.
  4. Use a mobile hotspot briefly to see if it’s router-related.
Also, check this guide of Certera.com Fix:- ERR_SSL_BAD_RECORD_MAC_ALERT.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CKStereAngel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 332
