跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
20 个问题 查看全部
Pairing issues after screen replacement
Hey guys, I'm unable to pair Apple Watch 3 GPS only version with any iphone. I tried to reboot iphone, delete network settings, try another phone, reboot watches. I've replaced the screen on the watches, they’re 1OO% unpaired and deleted from icloud. Phone starts pairing the watches but when it comes to activating the watches the iphone will stop the pairing and starts canceling the pairing process. Any recommendations?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Did you do a full reset of the watch?
完成的
Yes I did. You mean press on turn off then erase all data?
完成的
添加一条评论
1个答案
最有帮助的答案
Did you transfer your NFC module to your new display? Install Series 2 Display on a Series 3 with Apple Pay
这个答案有帮助吗?
得分 1
10条评论:
No, I didn't. But I've read more articles about it, i have original screen, this shouldn't be that issue...
完成的
I'm confused?? You stated you replaced the screen (full display assembly) so how could you still have the original display?
完成的
By original display i meant display from another watches. Original means that its not a copy from internet.
完成的
If you have a broken display in Watch A and took a good display from Watch B to put into Watch A then the NFC chip of Watch B is now inside Watch A unless you swapped them over independently of the display. Basically swapping the displays over (B to A) but still using Watch A's NFC in Watch A. If not the NFC services won't work.
Hopefully that explains your issue.
完成的
Is NFC related to pairing watch
I’m from India , here no Apple Pay
But I’m using S4 GPS Watch which was replaced with new screen & I used for couple of months then I erased Watch & unpair from my iPhone
Now while pairing my iPhone it was unpairing automatically with out any pop up message on screen
I tried with several phones but no use
If cause with Bluetooth & WiFi issues replacing screen flex cable is it resolved?
Help me also please
完成的
显示更多的5条评论
添加一条评论
添加你的答案
jrkstbl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,154
