跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
bluish spots lcd display MacBook Pro 15 inch 2016
my macbook pro’s display shows bluish spots. you can read about this issue here: https://discussions.apple.com/thread/830...
what is causing the problem? how many of you have the same issue? first keyboard-gate and now display-gate? how should i proceed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
I have the same problem on a refurbished 2017 MacBook Pro. Is there any fix for this? Please!
完成的
@Antoine Bonsorte - Sadly. you'll need a new display assembly
完成的
添加一条评论
2个答案
最有帮助的答案
Just like CRT’s which encounter burn-in, LCD’s also encounter image persistence. Unlike the electron beam burning the phosphor of the screen’s coating in a CRT. The liquid crystals in the panels sandwich can loose their elasticity returning back to their neutral position.
Brightness and heat tend to aggravate this when you have a static image which stresses the crystals.
As to this being a common occurrence within this series of MacBook Pro’s So far there just isn’t. The larger 27” displays tend to have a bigger issue with this across all makes of displays.
There are a few things you can do to improve things. First alter your background from an image to a solid color, ideally a mid grey. Next there are a few programs which can exercise the crystals within the panel, while the extreme damage won’t be corrected, minor damage does seem to get better.
Avoiding image persistence on Apple displays
这个答案有帮助吗?
得分 2
4条评论:
Hey, thanks for this information. I have the Bluish spots to.
Can you name me some software "which can exercise the crystals within the panel" ?
I didn't found anything which is helping, only software for dead pixels.
Thanks in advance
Eric
完成的
Sorry, no magic software ;-{
All I do is create a JPEG of the full screens dimensions (The RGB colors: Red, Green, Blue) which has the area altered that needs attention with the apposing color. Think how the Japanese flag looks with a Red center dot with a White field. Here I use a full Red background with a Green of the areas that need correction. Then I create a second JPEG which has Green where the Red was and use Blue where I has Green, Then I make a third JPEG which has the base Blue and the areas Red, the forth is then Red area Green, and the last Green and Blue.
OK now that you have the needed images lets automate it using Automator script flashing each in rotation for 1 second over and over again for a few days at high brightness that the best you can do. If that fails to improve things its time for a new display.
Thats what this app does LCD Scrub it does it across the full screen vs what I do.
完成的
I have this issue but have rarely used my Macbook Pro in Laptop mode, majority of it's time (38 out of 40 hours a week) it's attached to an external display and the lid closed, LCD off.
It's a very rorschach ink blotch test type of blotch
完成的
@notdavis - Your's is a bit different that's a cooked screen ;-{
The liquid within the LCD material the screen has evaporated out.
完成的
添加一条评论
This is not a burn in. I've had the screen replaced twice for this issue. I'm going for my third tomorrow. I'm sure many others have the same issue they just haven't noticed.
这个答案有帮助吗?
得分 0
1条评论:
mmarchant - You are very correct its not CRT Burn-In! What was clearly stated its LCD Image Persistence
I should have explained heat can cook the crystal liquid and freezing can break down the crystal liquid. So make sure you don't place your system in environments that can harm it.
Another issue is pressure spots as the gap between the two sheets of glass of the panel where the liquid sits can get squeezed out so the liquid is not present creating black splotches.
完成的
添加一条评论
添加你的答案
oscar 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 39
总计 4,770
