No option for "Adjust keyboard brightness in low light"?
I recently replaced the display on a MacBook Pro (13-inch, 2018, Four Thunderbolt 3 Ports) with Touch Bar and now the keyboard backlight is not adjusting automatically in low light. I’ve tried manually adjusting the keyboard backlight and there is no response. When I got to the appropriate system preferences for the keyboard there is no option for me to check or uncheck “Adjust keyboard brightness in low light“. It just lists the options “Touch Bar shows [Expanded Control Strip]“ and “Press Fn key to [Show F!, F2, etc. Keys]“. Has the keyboard backlight somehow been disabled, or could this be a result of a defective display? Thanks for any help you can provide!
4条评论
Where did you get the display and the P/N you ordered?
由 Dan 完成的
@danj Part number is 661-10037 purchased from la.tronics through eBay.
由 Zachary Lunte 完成的
Did you ever resolve this issue changed my screen using same supplier now no keyboard brightness. ?
由 Eadin Mitchell 完成的
We eventually determined that the display we received was incompatible. We replaced it with a separate known-good display from a same model machine and the issue was resolved.
由 Zachary Lunte 完成的
