跳转到主内容
Released November 2013, Model Number RCT6077W2, 4GB Storage, 7" Touchscreen.
19 个问题 查看全部
Turns On, Wont Work?
Recently I had rediscovered this tablet and decided to use it for work purposes. Not even a day later a friend of mine thought it would be funny to smack the think out of my hand and onto the hard pavement. Miraculously, The only physical damage that could be seen is a slight crack through the left part of the screen itself. However when the actual device itself is turned on the entire left side is simply unresponsive while the right works perfectly fine. I’v already tried most of the normal tips and tricks (turning it off and on, factory reset, etc,) but nothing seems to actually be working. What would be the best course of action?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
I’m assuming that the LCD screen is OK, i.e. full display on entire screen and that the touchscreen (aka digitizer) is not responding on the left side. Is this correct?
If so then the touchscreen either has a loose connection to the systemboard due to the fall or it is faulty (you mentioned a small crack) and needs to be replaced as it cannot be repaired.
Here’s a link to the ifixit RCA RCT6077W2 Repair guides, which may be of some help in gaining access to the digitizer’s motherboard connection so that you can check if it is OK or not and also the screen if you need to replace it.
Here’s a link to just one supplier for the replacement part.
It is shown only to give you an idea of the cost of the part and what it looks like. There are other suppliers online that may suit you better. Just search for RCA RCT6077W2 touchscreen to get results.
I suggest that you also bill your friend for the cost of the repair (and your time). After all this is their fault.
这个答案有帮助吗?
得分 1
1条评论:
Thanks again, I do appreciate it
完成的
添加一条评论
添加你的答案
Someone Noone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 24
