跳转到主内容
The Ridgid JobMax R2851 Series B can be identified by its model number: R2851- Series B. This device is 120 Volts, 60Hz, and 4.0 Amps.
How do you remove Sleeve Spacing Assembly?
how do you remove the metal from the Sleeve Spacing Assembly ? do you need a special pulley?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
You could probably use a bearing puller tool? Or clamp some underneath it such that it's not gripping the axle but is providing pressure to the lip of the sleeve, then on a hard surface use a hammer to hit the axle.
Damage in any case here could compromise the quality and safety of the repair.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 317
