跳转到主内容
Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
fan doesnt run automatically
when i use my imac then fan never runs atuomaticaly even though the top is burning but it works with smcfan control how do i make it run automaticaly?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Do an SMC reset. Unplug the power cord and let it sit for a few minutes. How can you tell that the fans are running at all? These machines idle very quiet. Install the iStat Pro widget to monitor fan speeds and temps.
这个答案有帮助吗?
得分 2
2条评论:
i already have stat pro its only on 1199 even when its burning hot
完成的
Try smc fancotrol (found easily via google) to ramp up the base speed of the fans. Something seems to be fishy with either the sensors or the smc itself on your machine. Unfortunately i can't tell more without actually seeing the computer. Doublecheck all wiring on the logicboard.
完成的
添加一条评论
heres info.
  • try using a different fan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mop2011 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 525
