跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Is replacement battery too thick?
I installed a replacement battery and a replacement screen, and it seems like the battery is too thick. I cannot get the case to close completely and there is a blue tinge on the screen at the upper left corner. I think the battery is pressing against the back of the screen.
I guess the problem might be the screen but it seems more likely that the problem is with the battery.
Or possibly I have done something wrong?
Update (10/26/2019)
I removed all of the old adhesive and used new adhesive strips. All new components are from ifixit.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Move the battery cover closer to the battery. (The black thing covering the battery looks like it is peeling away by the volume buttons.) This will be why you can't close the screen.
完成的
添加一条评论
1个答案
Can you post a photo so we can see where the pressure mark is?
If the battery is too far to the left, or too high up, then the screen will get caught as you go to close it, causing pressure marks.
If it looks like the image below then it should close properly, unless the battery is defective, or there is a bend in the phone chassis.
这个答案有帮助吗?
得分 0
1条评论:
I would add did you fully remove the old tape adhesive. from the battery well.
完成的
添加一条评论
添加你的答案
dwkarl 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 3
总计 292
