跳转到主内容
Model A1625. 2015 revision to Apple's set-top-box featuring an A8 processor and 2 GB of RAM.
30 个问题 查看全部
Replacing the wifi chip in my Apple TV 4
Hi,
My Apple TV 4 has a defective bluetooth/wifi chip. So I found one on eBay, a 339S00045 chip, which seems to be the same as in the ipad mini and pro. I took my apple tv apart, but the chip doesn’t seem to be that easy to replace. Is that something that is even possible at this point?
Regards,
Pieltre
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sadly this is a BGA chip which really needs a proper rework station to fix.
Basically, after you carefully remove the old chip you would clean the old solder off clean the board and then using a mask and the correct sized solder balls layout the field and then reflow the chip back on.
Given the cost of the needed equipment and sundries. I think it will be cheaper just getting a new Apple TV ;-{
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jean Maxime Lachance 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 25
总计 577
