跳转到主内容
加入维修社区 - 创建账户
于2015年十月26日上市的第四代Surface Pro平板电脑。
Surface pro 4 screen replacement
Hello, i’m new here.
I would like to ask you if you could tell me which screen is mounted. I read that there are two versions and that the sp4 tablet is born with the Samsung screen. Subsequently, due to flickering problems it appears that the screens have been replaced by LG screens.
below I post a picture.
I would also like to ask you if the model in ifixit is compatible with my device and that I avoid the flickering effect
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi pisanivito,
I believe your broken display is an LG sourced display. I have attached an image of a Samsung display. The differences are subtle and they are interchangeable, provided you use the correct connectors. If you choose to use the IFIXIT display, it will be compatible with your Surface Pro 4, but you will need to order the correct display connector PN: X937072-001 . The N-Trig Digitizer should just be a hot-swap and although your connector for that looks different from mine, it should work with a Samsung display just fine.
这个答案有帮助吗?
得分 0
添加一条评论
Hi Logan, pianivito,
I am doing the same upgrade myself. M1010537-003 is the correct part number for the LVDS display cable to upgrade a Surface Pro 4 to a newer LG display. Cable X937072-001 is for the Samsung unit in your screenshot
Cheers, Neil!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pisanivito 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 42
总计 859
