跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
MacBookPro won't turn on after battery replacement. Late 2013/A1398
After replacing the battery and trackpad per the iFixit tutorials, my Late 2013 15” MacBookPro won’t turn on. No fans, no lights, no nothing. Plugged into a charger, the charger light turns amber, and resetting the SMC while it is plugged in causes the charger light to go briefly from amber to green and back to amber (which makes me think the keyboard is connected correctly).
Any suggestions on what else to check or how to debug this? All connectors removed seem seated correctly and none were damaged during the removal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I had a similar issue after replacing my battery. I was able to fix it by removing the cable that connects the i/o board to the logic board, clean it out, and make sure it is seated correctly and snugly. After that cable was correct it booted right up.
这个答案有帮助吗?
得分 1
1条评论:
No &&^&^$^ way . Thanks
完成的
添加一条评论
添加你的答案
Kenneth Adelman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 456
